Problem: Completed print jobs remain visible in Samba print queues after upgrading to UCS 5.2-6
After upgrading from UCS 5.2-5 to UCS 5.2-6 with Samba 4.24.2, completed print jobs may remain visible in Windows/Samba print queues although CUPS has already processed them successfully.
For an affected printer, CUPS reports no active jobs:
lpstat -W not-completed -o <PRINTER>
while Samba still returns completed jobs:
rpcclient localhost -U Administrator -c 'enumjobs <PRINTER>'
/var/log/samba/log.rpcd_spoolss contains messages such as:
fetch_share_cache_time: Error fetching timing data for [<PRINTER>]. Err:Success
print_cache_expired: Unable to get last scan timing for <PRINTER>
Investigation
Check the relevant Samba printing database:
python3 - <<'PY'
import os
import tdb
printer = "<PRINTER>"
path = f"/var/cache/samba/printing/{printer}.tdb"
db = tdb.Tdb(path, flags=os.O_RDONLY)
for key in (
    b"INFO/version\x00",
    f"CACHE/{printer}\x00".encode(),
    f"MSG_PENDING/{printer}\x00".encode(),
    try:
        value = db[key]
        print(key.rstrip(b"\0").decode(), len(value), value.hex())
    except KeyError:
        print(key.rstrip(b"\0").decode(), "missing")
db.close()
PY
The affected state looks like this:
INFO/version 4 09000000
CACHE/<PRINTER> 4 ...
The database is already version 9, but the existing CACHE/<PRINTER> value still uses the old 4-byte format.
Root Cause
Samba 4.21 uses print database version 8 with 32-bit timing values.
After upgrading to Samba 4.24.2, the first access to an existing print database changes INFO/version from 8 to 9, but an existing 4-byte CACHE/<PRINTER> record is not migrated or removed.
Samba 4.24.2 expects this value in the new 8-byte format. Reading the old record fails, preventing the print cache from being refreshed correctly. Completed CUPS jobs can therefore remain in the Samba queue.
:bulb: See here for the bugreport.
As a workaround, remove only the obsolete CACHE/<PRINTER> record. Samba recreates it in the correct 8-byte format.
First verify that CUPS has no active jobs for the printer:
If the output is empty, stop Samba and create a backup:
systemctl stop samba-ad-dc
cp -a /var/cache/samba/printing/<PRINTER>.tdb /root/<PRINTER>.tdb.backup
Remove only the affected cache record:
python3 - <<'PY'
import tdb
db = tdb.Tdb(path)
key = f"CACHE/{printer}\x00".encode()
value = db[key]
print("removing:", len(value), value.hex())
del db[key]
db.close()
PY
Start Samba again:
systemctl start samba-ad-dc
Verify that stale jobs disappear:
The recreated cache record should now use 8 bytes:
python3 - <<'PY'
import os
import tdb
value = db[key]
db.close()
PY
Expected result:
CACHE/<PRINTER> 8 ...
This is a workaround for the affected print database state, not a permanent fix for the upgrade issue.
