Problem: Changes on portal not processed
Changes to the portal are not shown.
There may be other reasons but if the listener-notifier replication is disturbed, changes on the portal will not take place. So first step should be to verify the replication is working on master and (if not on the master) portal server. The diagnose module should tell you.
If replication is disturbed this article could help you.
