The rabbitmq-server service can’t be started. It fails with epmd reports: node 'rabbit' not running at all
The Logs under /var/log/rabbitmq/ contain:
Error description:
{could_not_start,rabbit,
{{badmatch,
{error,
{{{badmatch,
{error,
{not_a_dets_file,
"/var/lib/rabbitmq/mnesia/rabbit@snhucs01/recovery.dets"}}},
Environment
- UCS@school master node
- actual PostgreSQL (at time of writing: 9.6)
The recovery.dets file was corrupted, so the solution is to move it away and restart rabbitmq:
mkdir -p /tmp/badrabbit
mv /var/lib/rabbitmq/mnesia/rabbit@<hostname>/recovery.dets /tmp/badrabbit/
systemctl restart rabbitmq-server.service
You can now check if rabbitmq works again by systemctl status rabbitmq-server.service and rabbitmqctl status
Have fun
