Problem: Cannot print caused by handle is invalid
Cannot print, and Windows shows:
Handle is invalid
Der Vorgang konnte nicht abgeschlossen werden (Fehler:0x00000006)
The printdriver seems to be corrupt.
You should try to re-add the printer in UCS and configure it and then re-upload the printdriver (get a new one → download again, and do not just select the existing one!)
