See first the introducing article
Some default config seems not to fit any environment. Inside the docker container (some of) the following steps might be applied
Container Apache configuration
In the Apache2 container configuration for Bluespice, the following had to be adjusted for ports 80 and 443:
<Directory /var/www/bluespice>
Options FollowSymLinks MultiViews
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/bluespice/images>
AllowOverride None
AddType text/plain .html .htm .shtml .phtml .php .php3 .php4 .php5 .php7
php_admin_flag engine off
Require all granted
</Directory>
Bluespice local settings
If necessary the /etc/bluespice/LocalSettings.php must be adjusted to our needs:
# MySQL specific settings
$wgDBprefix = “bsp3”;
Run the update script
The maintenance script had to be executed:
php maintenance/update.php --quick
Adjust language
# Site language code, should be one of the list in ./languages/data/Names.php
$wgLanguageCode = “de”;
Rebuild Indices
Now the indices must be recreated
Purge
root@blues-14344585:/var/www/bluespice# php extensions/BlueSpiceExtendedSearch/maintenance/purgeIndexes.php
Init
root@blues-14344585:/var/www/bluespice# php extensions/BlueSpiceExtendedSearch/maintenance/initBackends.php
Rebuild
root@blues-14344585:/var/www/bluespice# php extensions/BlueSpiceExtendedSearch/maintenance/rebuildIndex.php
Run maintenance jobs
root@blues-14344585:~# php /var/www/bluespice/maintenance/runJobs.php
Adjust some rights
If necessary change ownership of these folders and inside files
chown -R www-data:www-data /opt/bluespice/cache
chown -R www-data:www-data /var/bluespice/images/
