soweit, so gut, aber leider treten diverse Fehler auf, von den der aktuelle dieser ist
Richte univention-ldap-server ein (2.4.11-2.267.200712101526) ...
Not updating ldap/autostart
File: /etc/init.d/slapd
File: /etc/ldap/replica.conf
File: /var/lib/univention-ldap/ldap/DB_CONFIG
Multifile: /etc/ldap/slapd.conf
Not updating ldap/debug/level
Not updating ldap/port
Not updating ldap/database/type
Not updating ldap/index/eq
Not updating ldap/index/pres
Not updating ldap/index/sub
Not updating ldap/index/approx
Not updating ldap/sizelimit
Not updating ldap/cachesize
Not updating ldap/threads
Not updating ldap/page-results
Not updating ldap/acl/user/kolab2/change
Not updating ldap/acl/user/password/change
Not updating ldap/database/bdb/db_config_options
Not updating ldap/database/bdb/set_flags
Not updating ldap/translogfile
/usr/share/univention-admin-tools/univention-dnsedit: timeout while trying to contact LDAP server dmoeko.gri-oekonet.de
/usr/share/univention-admin-tools/univention-dnsedit: LDAP server dmoeko.gri-oekonet.de unreachable, aborting
Stopping ldap server(s): slapd.
Check database: done
Starting ldap server(s): slapd.
authentication error: Authentisierung fehlgeschlagen
dpkg: Fehler beim Bearbeiten von univention-ldap-server (--configure):
Unterprozess post-installation script gab den Fehlerwert 3 zurück
Richte imp4 ein (4.1.3-4.11.200710191641) ...
Cannot find service-record of _pkgdb._tcp.
No DB-Server-Name found.
root@dmoeko:/var/backups#
Ein Teilauszug aus syslog sagt
Nov 28 18:08:25 dmoeko postfix/cleanup[24499]: warning: A7CB32BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko slapd[24437]: OVER: rs->sr_err != LDAP_SUCCESS on "dc=gri-oekonet,dc=de" ERR: 0x20
Nov 28 18:08:25 dmoeko postfix/cleanup[24498]: warning: dict_ldap_lookup: ldapaddressout: Search base 'dc=gri-oekonet,dc=de' not found: 32: No such object
Nov 28 18:08:25 dmoeko postfix/cleanup[24498]: warning: A7EF52BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko postfix/cleanup[24499]: warning: dict_ldap_lookup: ldapaddressout: Search base 'dc=gri-oekonet,dc=de' not found: 32: No such object
Nov 28 18:08:25 dmoeko postfix/cleanup[24499]: warning: A81502BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko postfix/cleanup[24498]: warning: A83B22BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko postfix/cleanup[24499]: warning: A86052BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko postfix/cleanup[24498]: warning: A884A2BD638: canonical_maps map lookup problem for www-data@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko postfix/cleanup[24499]: warning: A8AE72BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko postfix/cleanup[24498]: warning: A8D3A2BD638: canonical_maps map lookup problem for root@dmoeko.gri-oekonet.de
Nov 28 18:08:25 dmoeko slapd[24437]: OVER: rs->sr_err != LDAP_SUCCESS on "cn=admin,dc=gri-oekonet,dc=de" ERR: 0x31
Und aus der listener.log lässt sich dies ablesen
root@dmoeko:/var/backups# tail -f /var/log/univention/listener.log
28.11.08 18:07:34 DEBUG_INIT
28.11.08 18:07:35 LDAP ( ERROR ) : ldap_simple_bind: Invalid credentials
28.11.08 18:07:35 LISTENER ( WARN ) : can not connect to ldap server (dmoeko.gri-oekonet.de)
univention-directory-listener: unbind.c:40: ldap_unbind_ext: Assertion `( (ld)->ld_options.ldo_valid == 0x2 )' failed.
28.11.08 18:07:35 LISTENER ( WARN ) : received signal 6
28.11.08 18:08:35 DEBUG_INIT
28.11.08 18:08:35 LDAP ( ERROR ) : ldap_simple_bind: Invalid credentials
28.11.08 18:08:35 LISTENER ( WARN ) : can not connect to ldap server (dmoeko.gri-oekonet.de)
28.11.08 18:08:35 LISTENER ( WARN ) : received signal 6
Wie wäre denn eine Lösung des Problems zu finden. Natürlich versacht dieser Fehler, dass ein Anmelden an der Domäne nicht mehr möglich ist
MfG
Hightower
