Problem: Attempt To Prune Translog Entries Fails
You attempted to use the prune command on my Master UCS to reduce the size of the translog database because the translog database has reached almost 87% capacity (of 16GB).
The initial attempt to keep only 1,000,000 entries fails with:
    result = func(*args,**kwargs)
ldap.SIZELIMIT_EXCEEDED: {'desc': 'Size limit exceeded'}
This is a bug which has been fixed with UCS 4.4 e146. Upgrade to the latest version of UCS.
