In the execution /usr/share/univention-directory-notifier/univention-translog stat you get the following traceback and this will be also logged in /var/log/univention/notifier.log
File "/usr/share/univention-directory-notifier/univention-translog",
line 1472, in <module>
exit(main())
File "/usr/share/univention-directory-notifier/univention-translog", line 421, in main
return opt.func(opt) or 0
line 553, in show_stat
with Index(opt.translog_file) as index,
Translog(opt.translog_file, index) as
translog:
line 148, in __enter__
assert reminder == 0, reminder
AssertionError: 7
The AssertionError shows that the translog is corrupt and you need to reindex it.
You can do this with the following command.
/usr/share/univention-directory-notifier/univention-translog reindex
Reindexing will probably take some time, depending on the size of the LDAP.
