This problem was fixed with apple-school-manager 5.1.1.
Our ASM Connector fails when generating the CSV file for a staff member assigned to multiple schools. Specifically, if a staff member is configured as a substitute and assigned to around 20 schools, the script aborts with the following error:
AssertionError: No more than 14 additional locations are allowed.
ASM upload failed, see /var/log/univention/asm.log
The script currently enforces a limit of 14 additional school locations per staff member, which prevents the CSV generation for staff members assigned to more than 14 locations.
Root Cause
The issue arises from a hard-coded limitation in the ASM Python module. In the file /usr/lib/python3/dist-packages/univention/asm/models/staff.py, the code currently asserts:
assert len(additional_location_ids) < 15, "No more than 14 additional locations are allowed."
This restriction does not align with Apple’s documentation. While Apple has not officially documented a change to this limit, an undated support article suggests a much higher limit:
Apple Support: Assign multiple locations
According to this resource, staff members can be assigned up to 999 locations, making the current limit in the ASM Connector outdated.
A bug report has been created to align the ASM Connector with the updated Apple limit:
UCS Bugzilla Report #58988
To resolve this issue, you need to update the Python assertion in the staff.py file to allow more locations. Edit line 109 in /usr/lib/python3/dist-packages/univention/asm/models/staff.py as follows:
if additional_location_ids:
assert len(additional_location_ids) < 999, "No more than 999 additional locations are allowed."
else:
