Problem: ASM Connector - No Synchronisation to ASM
Problem ASM Connector - No Synchronisation to ASM
The connector no longer synchronizes the data to ASM. In the appcenter.log you can find such entries:
 17350 actions.configure                20-11-13 11:02:46 [ WARNING]:     course_name=school_class.name.split("-", 1)[1],
 17350 actions.configure                20-11-13 11:02:46 [ WARNING]: IndexError: list index out of range
If after a split
an Index out of Range Error follows
there is at least one element that does not contain this split separator. In this example we have to search for a school class without hyphen;
This class was created manually for testing purposes, and caused the problem. A correct classname always contains the school OU in the beginning and a hyphen between OU and given class name.
