The Apple School Manager app maps attributes incorrectly.
The “firstname” contains the username while the “lastname” attribute is empty.
Environment
The ucr- variables looks similar to the following:
Option 1
Disable anonymization.
ucr set asm/attributes/staff/anonymize=no
ucr set asm/attributes/student/anonymize=no
Thus, local usernames will be used for ASM.
Option 2
Keep anonymization but choose a different mapping.
Currently it is set to %uid:
asm/attributes/student/anonymize/first_name=%uid
asm/attributes/student/anonymize/last_name=-
You might use any attribute from univention-ldapsearch.
Sofern Sie die Anonymisierungsoptionen nicht benötigen, deaktivieren Sie diese am besten so:
asm mappt falsch, firstname ist Benutzername, lastname ist leer.
