Apple School Manager (ASM) throws (cosmetic) error at the end of upload.
Environment (optional)
UCS@school
At the end of the file upload we check the file by executing a stat on the file. Apple seems to move this file very fast so the stat fails.
We track this problem in Bug 54553.
Actual you can fix the problem by editing
/usr/lib/pymodules/python2.7/univention/asm/network/sftp_upload.py
Change this:
def upload(self, filename, remote_folder='/'):
remote_filename = os.path.join(remote_folder, 'archive.zip')
self.sftpClient.put(filename, remote_filename)
to this:
### patch Bug54553
#self.sftpClient.put(filename, remote_filename)
apple_supports_stat_call = False
self.sftpClient.put(filename, remote_filename, confirm=apple_supports_stat_call)
Watch the bug comments if the correction is published and the manual change is not necessary anymore.
