Your Kopano server does not start up after upgrading to UCS 4.3.
Case 1
You will see those errors in logs:
Mon Mar 26 11:29:37 2018: [error ] SQL [00000023] Failed: Cannot load from mysql.proc. The table is probably corrupted, Query Size: 33, Query: "DROP PROCEDURE IF EXIST$
Mon Mar 26 11:29:37 2018: [error ] KDatabase::I_Update() query failed: DROP PROCEDURE IF EXISTS GetProps: Cannot load from mysql.proc. The table is probably corrupted
Mon Mar 26 11:29:37 2018: [error ] Can't initialize database settings
Case 2
You will see the following in the logfile /var/log/kopano/server.log:
Mon Nov 19 08:38:16 2018: [error ] K-1216: Cannot update to schema v69, because the "names" table contains unexpected rows. Certain prior versions of the server erroneously allowed these duplicates to be added (KC-1108).
Mon Nov 19 08:38:16 2018: [error ] K-1220: To fix the excess rows, use `kopano-dbadm k-1216`. Consult the manpage and preferably make a backup first.
Mon Nov 19 08:38:16 2018: [error ] K-1221: Alternatively, the server may be started with --ignore-da to forego the schema update.
Mon Nov 19 08:38:16 2018: [warning] WARNING: Unable to upgrade database from version 8.6.2.0.68 to 8.6.2.0.70
Mon Nov 19 08:38:16 2018: [warning] You can force the server to start with --ignore-database-version-conflict
Mon Nov 19 08:38:16 2018: [warning] Warning, you can lose data! If you don't know what you're doing, you shouldn't be using this option!
Mon Nov 19 08:38:16 2018: [=======] Server shutdown complete.
Case 1
Sometimes during the upgrade the database upgrade procedure is not run correctly. You can start the conversion manually by:
/usr/bin/mysql_upgrade --defaults-extra-file=/etc/mysql/debian.cnf
If this runs without an error your Kopano server should now start.
Case 2
According to Kopano article do the following:
systemctl stop mysql
tar czpvf /root/mysql_backup.tar.gz /var/lib/mysql/ # to backup your database
systemctl start mysql
kopano-dbadm k-1216
systemctl start kopano-server
If this runs without an error your Kopano server should now be started.
