Problem: After failed install .schema cannot be registered
Hello!
After a failed installation try of bluespice I wanted to go over the process againg. So I hit the installation button for bluespice again and get the following mistake in my appcenter.log
31323 portalentries                    19-02-25 18:35:56 [   DEBUG]: DN not found...
31323 portalentries                    19-02-25 18:35:56 [   DEBUG]: ... creating
31323 actions.install                  19-02-25 18:35:56 [   DEBUG]: Calling /etc/init.d/apache2 reload
31323 actions.install                  19-02-25 18:35:57 [    INFO]: Reloading apache2 configuration (via systemctl): apache2.service.
31323 actions.install                  19-02-25 18:35:57 [   DEBUG]: /etc/init.d/apache2 returned with 0
31323 actions.install.progress         19-02-25 18:35:57 [   DEBUG]: 10
31323 database                         19-02-25 18:35:57 [   DEBUG]: bluespice=3.0.1-ucs.1 uses MySQL
31323 packages                         19-02-25 18:35:57 [   DEBUG]: Calling /usr/bin/apt-mark manual univention-mysql
31323 packages                         19-02-25 18:35:57 [    INFO]: univention-mysql wurde bereits auf manuell installiert gesetzt.
31323 database                         19-02-25 18:35:57 [   DEBUG]: Calling service mysql start
31323 database                         19-02-25 18:35:58 [   DEBUG]: Password already exists
31323 database                         19-02-25 18:35:58 [    INFO]: Checking if database bluespice exists (mysql implementation)
31323 database                         19-02-25 18:35:58 [   DEBUG]: Database and User already exist
31323 database                         19-02-25 18:35:58 [    INFO]: bluespice=3.0.1-ucs.1 already has its database
31323 actions.install.progress         19-02-25 18:35:58 [   DEBUG]: 15
31323 actions.install                  19-02-25 18:35:58 [    INFO]: Registering schema /usr/share/univention-appcenter/apps/bluespice/bluespice.schema
31323 packages                         19-02-25 18:38:59 [   DEBUG]: Releasing LOCK
31323 actions.install                  19-02-25 18:38:59 [CRITICAL]: Registering schema file /usr/share/univention-appcenter/apps/bluespice/bluespice.schema failed
31323 actions.install                  19-02-25 18:38:59 [ WARNING]: Aborting...
I don’t know how to solve the “Regisering schema bluespice.schema failed” problem.
Thanks for your help!:wink:
this log is just saying that there was an error. Maybe /var/log/univention/management-console-module-appcenter.log and /var/log/univention/join.log could tell us more about the reason.
Best Regards,
Dirk
