Additional attributes like an employeeNumber for users or the displayName of groups need to be synced by the AD-Connector.
Recommendation
Since UCS 4.4-7 we introduced the localmapping.
To map additional attributes you can define a mapping hook inside the (newly to be created) file /etc/univention/connector/ad/localmapping.py like this:
# import univention.connector # optional, because localmapping itself is loaded into a file, where the import has already taken place
def mapping_hook(ad_mapping):
ad_mapping['user'].post_attributes['employeeNumber'] = \
univention.connector.attribute(
ucs_attribute='employeeNumber',
ldap_attribute='employeeNumber',
con_attribute='employeeNumber'
ad_mapping['group'].attributes['displayName'] = \
ucs_attribute='DisplayName',
ldap_attribute='displayName',
con_attribute='displayName'
return ad_mapping
where the ucs_attribute represents the UDM name and con_attribute the AD name.
Or another example: Changing containers (cn) to organizational units (ou) - in this case the containers for student and teacher users
# import of Univention Configuration Registry (needed for referencing the ldap-base via ucr variable `ldap/base`)
from univention.config_registry import ConfigRegistry
# loading Univention Configuration Registry
ucr = ConfigRegistry()
ucr.load()
# the actual mapping
# position mapping (switch container for 'schueler' below cn='users' and school-ou='testschule' ("cn" -> "ou")
ad_mapping['user'].position_mapping=[('cn=schueler,cn=users,ou=testschule,%(ldap/base)s' % ucr, 'OU=schueler,CN=users,OU=Testschule,%(connector/ad/ldap/base)s' % ucr)]
# position mapping (switch container for 'lehrer' below cn='users' and school-ou='testschule' ("cn" -> "ou")
ad_mapping['user'].position_mapping=[('cn=lehrer,cn=users,ou=testschule,%(ldap/base)s' % ucr, 'OU=lehrer,CN=users,OU=Testschule,%(connector/ad/ldap/base)s' % ucr)]
return ad_mapping
Alternative Syntax for the same example:
# import von Univention Configuration Registry (wird z.B: für `%(ldap/base)s' % ucr` benötigt)
# Laden von Univention Configuration Registry (s.u.)
ucr.load()
# import univention.connector # optional, weil das localmapping selbst in eine Datei geladen wird, wo der Import schon vorgenommen wurde
# eigentliches Mapping beginnt
custom_position_mapping = [
('cn=schueler,cn=users,ou=testschule,%(ldap/base)s' % ucr, 'OU=schueler,CN=users,OU=testschule,%(connector/ad/ldap/base)s' % ucr),
('cn=lehrer,cn=users,ou=testschule,%(ldap/base)s' % ucr, 'OU=lehrer,CN=users,OU=testschule,%(connector/ad/ldap/base)s' % ucr)
ad_mapping['user'].position_mapping = custom_position_mapping
return ad_mapping
or
Exclude that the attribute “description” is synced.
cat /etc/univention/connector/ad/localmapping.py
ad_mapping['group'].attributes.pop('description')
return ad_mapping
Sync HomeDirectory to AD
ad_mapping['user'].post_attributes['homeDirectory'] = \
ucs_attribute='sambahome',
ldap_attribute='sambaHomePath',
con_attribute='homeDirectory'
return ad_mapping
Further reading
- Install Active Directory Domain Services on Windows Server 2019
- Connect UCS to existing AD Domain
- Manual entry for localmapping.py
- https://git.knut.univention.de/univention/ucs/-/blob/5.0-6/services/univention-ad-connector/modules/univention/connector/ad/mapping.py#L301 → internal use, to get the mapping
