Problem: AD Connector services repeatedly restarting
The AD Connector services (univention-ad-con_*) are observed to restart or stop repeatedly, typically occurring around midnight (00:00). In environments with multiple AD connector instances, these restarts may happen in very short intervals (seconds), leading to service instability or total failure.
Cause
This issue is caused by a misconfigured logrotate setting. When a wildcard is used to specify multiple log files (e.g., /var/log/univention/con_*.log) and a postrotate script is defined to restart the services, logrotate’s default behavior is to execute the postrotate script for every single file that matches the pattern and is rotated.
If multiple log files match the pattern, the restart command (e.g., systemctl try-restart univention-ad-con_*) is triggered multiple times in rapid succession. This creates a “restart storm” that prevents the services from remaining stable and available.
There are to ways to resolve this.
  1. Add the sharedscripts directive to the logrotate configuration file. This directive ensures that the postrotate script is executed only once at the end of the rotation cycle, regardless of how many files were rotated.
Example of problematic configuration:
In this example, the postrotate script runs for every .log file found.
/var/log/univention/con_*.log {
        compress
        create 640 root adm
        missingok
        notifempty
        daily
        maxsize 500M
        rotate 12
        postrotate
                systemctl try-restart univention-ad-con_* > /dev/null
        endscript
This would look like this:
        compress
        create 640 root adm
        missingok
        notifempty
        daily
        maxsize 500M
        rotate 12
        sharedscripts
        postrotate
        endscript
  1. Solution, which comes with a better stability and predictability, it is recommended to explicitly list the services to be restarted in the postrotate script instead of using wildcards:
        postrotate
                systemctl try-restart univention-ad-con_service1.service > /dev/null
                systemctl try-restart univention-ad-con_service2.service > /dev/null
        endscript
