Ad-Connector reject for windows clients like:
2026-01-09T11:09:38.064976+01:00 ERROR [ -] sync_from_ucs: traceback during add object: cn=cat-nk01-04,ou=computer,ou=managedclients,DC=schein,DC=me
2026-01-09T11:09:38.065143+01:00 ERROR [ -] sync_from_ucs: traceback due to addlist: [('objectClass', [b'top', b'computer']), ('userAccountControl', [b'4096'])
, ('cn', [b'CAT-NK01-04']), ('description', [b'.']), ('operatingSystem', [b'Windows 11 Education']), ('operatingSystemVersion', [b'10.0 (26100)']), ('sAMAccountName', [b' CAT-NK01-04$'])]
2026-01-09T11:09:38.070825+01:00 WARNING [ -] sync failed, saved as rejected
File "/usr/lib/python3/dist-packages/univention/connector/__init__.py", line 803, in __sync_file_from_ucs
if not self.sync_from_ucs(key, mapped_object, pre_mapped_ucs_dn, old_dn, object_old): ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
File "/usr/lib/python3/dist-packages/univention/connector/ad/__init__.py", line 2153, in sync_from_ucs
self.lo_ad.lo.add_ext_s(object['dn'], addlist, serverctrls=ctrls)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 1009, in add_ext_s
return self._apply_method_s(SimpleLDAPObject.add_ext_s,*args,**kwargs)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 968, in _apply_method_s
return func(self,*args,**kwargs)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 222, in add_ext_s
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 543, in result3
resp_type, resp_data, resp_msgid, decoded_resp_ctrls, retoid, retval = self.result4(
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 553, in result4
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 128, in _ldap_call
result = func(*args,**kwargs)
ldap.ALREADY_EXISTS: {'msgtype': 105, 'msgid': 23, 'result': 68, 'desc': 'Already exists', 'ctrls': [], 'info': '00000524: UpdErr: DSID-031A11DA, problem 6005 (ENTRY_EXISTS), data 0\n'}
It’s useless (but we do) to synchronize Windows computer objects between UCS and Microsoft AD domains, because they are only joined into one of both domains.
In this case, why the reject comes up, the object in ad changed its position, without the connectors notice, and therefor in the sqlite database, the mapping between the object in UCS and the object in AD was not adjusted.
sqlite3 /etc/univention/connector/internal.sqlite 'select * from "DN Mapping UCS"' | grep -i cn=cat-nk01-04
cn=cat-nk01-04,ou=computer,ou=managedclients,dc=portal,dc=schein,dc=intranet|cn=cat-nk01-04,ou=raum-01,ou=cat,ou=wlan-notebooks,ou=schulgeraete,ou=managedclients,dc=schein,dc=me
To get this adjusted, and knowing that the clients are joined in ad, we can resync the object from ad to ucs
/usr/share/univention-ad-connector/resync_object_from_ad.py 'CN=CAT-NK01-04,OU=raum-01,OU=cat,OU=WLAN-Notebooks,OU=schulgeraete,OU=managedclients,DC=schein,DC=me'
