Synchronization issues with the AD-Connector arise when ignore-filters are removed and nested Distinguished Names (DNs) are edited, leading to errors such as:
ldap.NO_SUCH_OBJECT: {'desc': 'No such object', 'matched': 'ou=last,dc=found,dc=match,dc=com'}
Environment
This issue occurs in environments where Active Directory (AD) is synchronized with Univention Corporate Server (UCS) using the AD-Connector.
To handle changes when a previously ignored tree is added to synchronization:
- Ensure that all parent Organizational Units (OUs) exist.
- Force synchronization for each entity within the newly added tree using the appropriate script:
resync_object_from_ad.pyfor AD to UCS synchronization. -
resync_object_from_ucs.pyfor UCS to AD synchronization.
Root Cause
The AD-Connector, after the initial synchronization, does not verify the existence of parent OUs when an element is checked for synchronization. This can lead to synchronization errors if the necessary parent OUs are missing.
