Problem: AADSTS50008: Unable to verify token signature. The signing key identifier does not match any valid registered keys
After logging in to Office 365, you receive the following error message after forwarding to https://login.microsoftonline.com/login.srf
“AADSTS50008: Unable to verify token signature. The signing key identifier does not match any valid registered keys”
Investigation:
Check if:
  1. the ucs-sso certificates has not changed
saml/idp/certificate/certificate
saml/idp/certificate/privatekey
  1. the ucr variable saml/idp/entityID has not changed
A good way is to consult the/var/log/univention/config-regestry-replog file
You should reset the ucr variable for the entityID
ucr get saml/idp/entityID
https://ucs-sso.schein.ig/simplesamlphp/saml2/idp/metadata.php
ucr set saml/idp/entityID=https://ucs-sso.schein.ig/simplesamlphp/saml2/idp/metadata.php
Setting saml/idp/entityID
Multifile: /etc/simplesamlphp/metadata/saml20-idp-hosted.php
