After some issues during upgrade, a popup is shown in the right corner in UMC/Portal:
Warnung
Die Aktualisierung auf UCS 5.2-4 ist fehlgeschlagen. Bitte rufen Sie das Modul “Software-Aktualisierung” auf um mehr Informationen zu erhalten.
If the update is fine, and no more updates are availabe you can check for leftover here and edit the file to, how it shoult look like:
cat /var/lib/univention-updater/univention-updater.status
current_version=5.2-3
type=NET
status=FAILED
next_version=5.2-4
target_version=5.2-4
errorsource=POSTUP
This file should look like this:
current_version=5.2-4
type=NET
status=DONE
and a 0 Byte file named upgrade-failed.
These files are responsible for the popup
