Problem: 99ucs-school-umc-printermoderation.inst failed (exitcode: 1)
Investigation:
In /var/log/univention/join.log you find:
Failed to bind - LDAP error 49 LDAP_INVALID_CREDENTIALS -  <8009030C: LdapErr: DSID-0C0904DC, comment: AcceptSecurityContext error, data 52e, v1db1> <>
Failed to connect to 'ldaps://rs1.schein.ig' with backend 'ldaps': LDAP error 49 LDAP_INVALID_CREDENTIALS -  <8009030C: LdapErr: DSID-0C0904DC, comment: AcceptSecurityContext error, data 52e, v1db1> <>
Failed to connect to ldaps://rs1.schein.ig - LDAP error 49 LDAP_INVALID_CREDENTIALS -  <8009030C: LdapErr: DSID-0C0904DC, comment: AcceptSecurityContext error, data 52e, v1db1> <>
→ Seems to be a samba -issue
You get the same, if you do an univention-s4search
Looking in the logfile /var/log/samba/log.samba you will find
GSS server Update(krb5)(1) Update failed:  Miscellaneous failure (see text): Failed to find SMB$@SCHEIN.IG(kvno 39) in keytab FILE:/etc/krb5.keytab (aes256-cts-hmac-sha1-96)
or
Failed to bind to uuid e3514235-4b06-11d1-ab04-00c04fc2dcd2 for ncacn_ip_tcp:2a00:1e80:71:1:250:56ff:fea6:6901[49153,seal,krb5,target_hostname=6ed13bb0-151c-426e-81c4-40f9e632ae79._msdcs.schein.ig,target_principal=GC/backup.schein.ig/schein.ig,abstract_syntax=e3514235-4b06-11d1-ab04-00c04fc2dcd2/0x00000004,localaddress=2a00:1e80:71:1:250:56ff:fea6:592] NT_STATUS_UNSUCCESSFUL
Compare the secret in DB
ldbsearch -H /var/lib/samba/private/secrets.ldb \
objectClass=primaryDomain secret msDS-KeyVersionNumber
with
/etc/machine.secret
If these are identical, compare the KeyVersionNumber
ldbsearch -H /var/lib/samba/private/sam.ldb 'samAccountName=rs1$' msDS-KeyVersionNumber
# record 1
dn: CN=RS1,OU=Domain Controllers,DC=schein,DC=ig
msDS-KeyVersionNumber: 1
And also check with the keytab file
ktutil -k /etc/krb5.keytab list
/etc/krb5.keytab:
Vno  Type                     Principal                         Aliases
  2  des-cbc-crc              HOST/primary@SCHEIN.IG
  2  des-cbc-crc              HOST/primary.schein.ig@SCHEIN.IG
  2  des-cbc-crc              host/primary.schein.ig@SCHEIN.IG
  2  des-cbc-crc              ldap/primary.schein.ig@SCHEIN.IG
  2  des-cbc-crc              PRIMARY$@SCHEIN.IG
  2  des-cbc-md5              HOST/primary@SCHEIN.IG
  2  des-cbc-md5              HOST/primary.schein.ig@SCHEIN.IG
  2  des-cbc-md5              host/primary.schein.ig@SCHEIN.IG
  2  des-cbc-md5              ldap/primary.schein.ig@SCHEIN.IG
  2  des-cbc-md5              PRIMARY$@SCHEIN.IG
  2  arcfour-hmac-md5         HOST/primary@SCHEIN.IG
  2  arcfour-hmac-md5         HOST/primary.schein.ig@SCHEIN.IG
  2  arcfour-hmac-md5         host/primary.schein.ig@SCHEIN.IG
  2  arcfour-hmac-md5         ldap/primary.schein.ig@SCHEIN.IG
  2  arcfour-hmac-md5         PRIMARY$@SCHEIN.IG
  2  aes128-cts-hmac-sha1-96  HOST/primary@SCHEIN.IG
  2  aes128-cts-hmac-sha1-96  HOST/primary.schein.ig@SCHEIN.IG
  2  aes128-cts-hmac-sha1-96  host/primary.schein.ig@SCHEIN.IG
  2  aes128-cts-hmac-sha1-96  ldap/primary.schein.ig@SCHEIN.IG
  2  aes128-cts-hmac-sha1-96  PRIMARY$@SCHEIN.IG
  2  aes256-cts-hmac-sha1-96  HOST/primary@SCHEIN.IG
  2  aes256-cts-hmac-sha1-96  HOST/primary.schein.ig@SCHEIN.IG
  2  aes256-cts-hmac-sha1-96  host/primary.schein.ig@SCHEIN.IG
  2  aes256-cts-hmac-sha1-96  ldap/primary.schein.ig@SCHEIN.IG
  2  aes256-cts-hmac-sha1-96  PRIMARY$@SCHEIN.IG
If there is only “2” in the keytab, the authentication failes
Change the password in samba via samba-tool again. This will automatically raise the KeyVersionNumber.
You should backup /etc/krb5.keytab first
cp /etc/krb5.keytab{,.bak}
samba-tool user setpassword "$(hostname -s | tr '[:lower:]' '[:upper:]')$" --newpassword="$(</etc/machine.secret)"
It could also be possible to trigger the server password change:
