Versions
UCS: 5.0-1 errata225 (Virtual Box OVA)
Client: Windows 10 Pro (21H2 - build 19044.1526)
Printer driver: Brother Universal Printer (BR-Script3) (1.18.1.0)
Names
Domain: TEST (test.lan)
UCS PDC: ucs.test.lan (192.168.3.12)
UCS BDC: ucs-backup.test.lan (192.168.3.9)
Client: WIN10-TEST-9999.test.lan (192.168.3.2)
Printer: DCP-9020CDW
Description
I have the error 0x0000010b when downloading the printer driver from PDC.
Procedure followed
- Domain creation + backup join
- Win10 client join
- Download and copy the custom .ppd file from here:
Téléchargement | DCP-9020CDW | France | Brother > Printer Drivers > CUPSwrapper printer driver (deb package) to /usr/share/ppd/DCP-9020CDW.ppd - Link this .ppd to UMC > LDAP directory > univention > cups > Brother
- Create Printer Share from UMC > Printers > DCP-9020CDW, with the custom model referenced
- (Printer is visible in CUPS port 631 interface)
- Add Administrator domain account to Printer-Admins group
- Log as this account to Win10 client
- Create a new OU named Printer Deployed and move Win10 object to that OU:
- Create a new GPO (named GPO - Printer Deployed) linked to that OU with 2 options to remove printer installation warnings :
- Apply GPO (gpupdate /force with no error; then gpresult -r)
- Go to Print Management tool and add ucs.test.lan as print server
- Add 1 driver > Pilotes > Tout afficher > Pilote d’Imprimante Universel BR-Script (émulation de language PostScript) (64 and 32 bits) using Univention documentation:
- Driver upload is successful (can see it in /var/lib/samba/drivers/ on PDC)
- Open DCP-9020CDW properties, click “No” to warning, and link driver; then click “Apply”; rename entry as Windows rename it automatically with the driver name, and the result is the following:
- Then deploy the printer using previous GPO:
- Apply GPO; reboot; then got this error:
Error 0x0000010b means Directory name is not valid. - I have the exact same error when manually connecting the share using Windows explorer (ucs.test.lan\DCP-9020CDW):
Windows cannot retrieve the driver and install it.
Thank you
EDIT: I have the following network flow when try to connect at step 18 (change .txt to .zip to find a wireshark capture file):print.txt (2.1 MB)
