Hi@all,
I have updated my Primary Directory Node and the Replica to 5.2. However, I still have two Managed Nodes running apps that have not yet been migrated to 5.2 (e.g., NextCloud). On these two systems, I get the following in the system diagnostics:
Critical: SAML certificate check failed
Certificate https://ucs-sso.lan.meinedomain.de/simplesamlphp/saml2/idp/certificate could not be loaded: Unable to load certificate. See Frequently asked questions — Cryptography 46.0.0.dev1 documentation for more details.
Certificate https://192.168.83.5/simplesamlphp/saml2/idp/certificate could not be loaded: Unable to load certificate. See Frequently asked questions — Cryptography 46.0.0.dev1 documentation for more details.
Run the join script 92univention-management-console-web-server via the “Domain Join” module or with the command univention-run-join-scripts --force --run-scripts 92univention-management-console-web-server as root.
I have already forced all join scripts to run and restarted the systems, but this message is not resolved. The Primary no longer runs SimpleSAMLphp. What do I need to do on the Managed Nodes (5.0.x) to make this message disappear?
with best
sven
