Portal Preview Downgrade or Reset
I had downloaded and installed the Portal Preview and while I like the update, some of my entries were not working and I wanted to downgrade to the original version, however I am not completely sure how to do this.
Is there a simple way to just “reset” the portal to either 1) Downgrade or 2) keep the Preview but set all values to “default”?
Thanks
did you find a way to activate the “Old” Portal ?
I have installed the Preview. Now the Portal is no longer working…
Tanks
No I have not, I have simply been bookmarking the Admin page so that I skip the portal. Not ideal
Hello Guys, I have a big problem with the first page of Univention portal with the preview version.
On the first page I can`t add any icons and login to the portal, also I have a problem going back to an earlier version (stable).
Can someone help me? There is somewhere script on how to remove the preview version of the portal?
Below my screen from portal.
univention
Any news, i would also like to downgrade to portal version 4. So many problems.
I have not gotten around to actually removing the Portal Preview, which is fine I guess considering the imminent upgrade to 5.0.
BUT
Will there be an app update that allows my system to upgrade to 5.0 with the Portal Preview installed? It still shows as “not available” so the upgrade cannot occur.
If there is no planned update then I will have to figure out how to remove or downgrade the portal
Any updates to this? I want to upgrade but want the Portal Preview cleanly removed first
