I don’t know if or how this one would refer to my problem, but it doesn’t help me.
as a matter of fact I didn’t want to migrate my VM anywhere else. I just wanted to stop it due to a restart of the hosting UCS-machine (now on 4.3, err 456)… everything went smooth until I wanted to restart said VM via UVMM.
the VM shows “paused” with a “?” at the end of the row. On mouseover I’m getting a note that it’s gonna be restarted after migration had ended.
Since I haven’t started a migration (nor do I want to do that) what can I do to get it restarted?
already looking forward to your advices
Thanks in advance
JK
There might be a chance to use the virsh commandline to resume or destroy and start the machine.
As far as I remember UVMM will also recognize these state changes even it did not do them himself.
Administrator@ucs:~$ virsh list --all
Id Name State
i remember that i once set up a personal pool and called it “VirtuelleMaschinen” and yes said VM was mounted there.
But somehow I can’t connect to “VirtuelleMaschinen” nor am I able to get to any information about it using virsh
