today i did the 5.0.3 update. After the Update i simply check all features.
the password reset fails.
Background:
The Users can access the replica node to use “forget password”
If i type in my test user, i get this:
Log on replica:
management-console-web-server.log
16.02.23 11:04:18.714 MAIN ( PROCESS ) : CPCommand (10.0.0.101:52074) response result: None
16.02.23 11:05:01.504 MAIN ( PROCESS ) : CPCommand (10.0.0.101:58580) response status code: 591
16.02.23 11:05:01.504 MAIN ( PROCESS ) : CPCommand (10.0.0.101:58580) response reason : None
16.02.23 11:05:01.504 MAIN ( PROCESS ) : CPCommand (10.0.0.101:58580) response message: Interner Server-Fehler in "passwordreset/get_reset_methods".
log on primary:
management-console-module-passwordreset.log
16.02.23 11:03:14.008 DEBUG_INIT
16.02.23 11:03:14.831 MODULE ( PROCESS ) : Loading Python module.
16.02.23 11:03:15.313 MODULE ( PROCESS ) : Imported Python module.
16.02.23 11:03:15.313 MODULE ( PROCESS ) : Module instance created.
16.02.23 11:03:15.314 MODULE ( PROCESS ) : Module socket initialized.
16.02.23 11:03:15.350 MODULE ( PROCESS ) : Setting user LDAP DN 'cn=secondary,cn=dc,cn=computers,dc=domain,dc=tld'
16.02.23 11:03:15.350 MODULE ( PROCESS ) : Setting auth type to Ntld
16.02.23 11:03:15.350 MODULE ( PROCESS ) : Initializing module.
16.02.23 11:03:15.376 MODULE ( PROCESS ) : get_plugins(): Plugin class 'SendWithExternal' for sending method 'Ntld' is disabled.
16.02.23 11:03:15.381 MODULE ( PROCESS ) : get_plugins(): Loaded sending plugin class 'SendEmail' for sending method 'email'.
16.02.23 11:03:15.386 MODULE ( PROCESS ) : get_plugins(): Loaded sending plugin class 'VerifyEmail' for sending method 'verify_email'.
16.02.23 11:03:15.396 MODULE ( PROCESS ) : get_plugins(): Plugin class 'SendSMS' for sending method 'mobile' is disabled.
16.02.23 11:03:15.396 MODULE ( PROCESS ) : get_plugins(): plugin class 'SendEmail' for sending method 'email': udm_property: 'PasswordRecoveryEmail' token_length: '64'
16.02.23 11:03:15.396 MODULE ( PROCESS ) : get_plugins(): plugin class 'VerifyEmail' for sending method 'verify_email': udm_property: 'PasswordRecoveryEmailVerified' token_length: '64'
16.02.23 11:03:15.408 MODULE ( ERROR ) : prevent_denial_of_service() could not find username argument. self: <univention.management.console.modules.passwordreset.Instance object at 0x7fc61cddc6d8> args: (<univention.management.console.protocol.message.Message object at 0x7fc613fdcfd0>,) kwargs: {} exception: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/univention/management/console/modules/passwordreset/__init__.py", line 169, in _decorated
username = args[0].options["username"]
KeyError: 'username'
16.02.23 11:03:15.410 MODULE ( PROCESS ) : Interner Server-Fehler in "passwordreset/get_reset_methods".
management-console-server.log
16.02.23 11:11:56.990 MODULE ( PROCESS ) : Setting auth type to None
16.02.23 11:11:57.150 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m passwordreset -s /run/univention-management-console/1093-1676542317150.socket -d 2 -l de_DE.UTF-8
16.02.23 11:11:59.627 MAIN ( WARN ) : Client: _recv: error on socket: [Errno 104] Die Verbindung wurde vom Kommunikationspartner zurückgesetzt
16.02.23 11:11:59.627 MAIN ( WARN ) : Socket died (module=udm)
16.02.23 11:11:59.627 MAIN ( WARN ) : Module process udm died (pid: 9109, exit status: -1, signal: -1, status: -1)
16.02.23 11:11:59.628 MAIN ( WARN ) : Cleaning up requests
16.02.23 11:11:59.628 MAIN ( WARN ) : Invalidating all pending requests 167654231962506-15
16.02.23 11:11:59.628 MAIN ( PROCESS ) : ModuleProcess: stopping 9109
16.02.23 11:11:59.628 MAIN ( WARN ) : Socket died (module=udm)
16.02.23 11:11:59.774 MAIN ( WARN ) : Socket died (module=join)
16.02.23 11:11:59.775 MAIN ( WARN ) : Module process join died (pid: 9111, exit status: -1, signal: -1, status: -1)
16.02.23 11:11:59.775 MAIN ( WARN ) : Cleaning up requests
16.02.23 11:11:59.775 MAIN ( PROCESS ) : ModuleProcess: stopping 9111
16.02.23 11:11:59.775 MAIN ( WARN ) : Socket died (module=join)
16.02.23 11:11:59.967 MAIN ( WARN ) : Socket died (module=updater)
16.02.23 11:11:59.967 MAIN ( WARN ) : Module process updater died (pid: 9122, exit status: -1, signal: -1, status: -1)
16.02.23 11:11:59.968 MAIN ( WARN ) : Cleaning up requests
16.02.23 11:11:59.968 MAIN ( PROCESS ) : ModuleProcess: stopping 9122
16.02.23 11:11:59.968 MAIN ( WARN ) : Socket died (module=updater)
16.02.23 11:12:00.203 MAIN ( WARN ) : Client: _recv: error on socket: [Errno 104] Die Verbindung wurde vom Kommunikationspartner zurückgesetzt
16.02.23 11:12:00.204 MAIN ( WARN ) : Socket died (module=appcenter)
16.02.23 11:12:00.204 MAIN ( WARN ) : Module process appcenter died (pid: 9124, exit status: -1, signal: -1, status: -1)
16.02.23 11:12:00.204 MAIN ( WARN ) : Cleaning up requests
16.02.23 11:12:00.204 MAIN ( WARN ) : Invalidating all pending requests 167654231999777-17
16.02.23 11:12:00.204 MAIN ( PROCESS ) : ModuleProcess: stopping 9124
16.02.23 11:12:00.205 MAIN ( WARN ) : Socket died (module=appcenter)
16.02.23 11:12:08.160 MAIN ( WARN ) : Socket died (module=ucr)
16.02.23 11:12:08.161 MAIN ( WARN ) : Module process ucr died (pid: 9250, exit status: -1, signal: -1, status: -1)
16.02.23 11:12:08.161 MAIN ( WARN ) : Cleaning up requests
16.02.23 11:12:08.161 MAIN ( PROCESS ) : ModuleProcess: stopping 9250
16.02.23 11:12:08.161 MAIN ( WARN ) : Socket died (module=ucr)
Systemcheck ran fine, no errors on all mashines.
Any idea? i didnt find any similar in the Forum.
Thanks
