UCS 4.4-8 errat 1108
When requesting a password token via email, the system returns Error no 111 (connection refused). It appears postfix is simply refusing to accept the connection. There isn’t a corresponding log entry in mail.info. I must be missing an entry in the ucr.
Any recommendations?
management log shows:
19.11.21 19:22:11.646 MODULE ( PROCESS ) : Initializing module.
19.11.21 19:22:11.675 MODULE ( PROCESS ) : get_plugins(): Loaded sending plugin class ‘VerifyEmail’ for sending method ‘verify_email’.
19.11.21 19:22:11.694 MODULE ( PROCESS ) : get_plugins(): Plugin class ‘SendSMS’ for sending method ‘mobile’ is disabled.
19.11.21 19:22:11.703 MODULE ( PROCESS ) : get_plugins(): Loaded sending plugin class ‘SendEmail’ for sending method ‘email’.
19.11.21 19:22:11.719 MODULE ( PROCESS ) : get_plugins(): Plugin class ‘SendWithExternal’ for sending method ‘None’ is disabled.
19.11.21 19:22:11.719 MODULE ( PROCESS ) : get_plugins(): plugin class ‘VerifyEmail’ for sending method ‘verify_email’: udm_property: ‘PasswordRecoveryEmailVerified’ token_length: ‘64’
19.11.21 19:22:11.719 MODULE ( PROCESS ) : get_plugins(): plugin class ‘SendEmail’ for sending method ‘email’: udm_property: ‘PasswordRecoveryEmail’ token_length: ‘64’
19.11.21 19:22:13.407 MODULE ( ERROR ) : Unknown error: Traceback (most recent call last):
File “/usr/lib/python2.7/dist-packages/univention/management/console/modules/passwordreset/init.py”, line 976, in _call_send_msg_plugin
plugin.send()
File “/usr/lib/python2.7/dist-packages/univention/management/console/modules/passwordreset/sending/send_email.py”, line 121, in send
smtp = smtplib.SMTP(self.server)
File “/usr/lib/python2.7/smtplib.py”, line 256, in init
(code, msg) = self.connect(host, port)
File “/usr/lib/python2.7/smtplib.py”, line 316, in connect
self.sock = self._get_socket(host, port, self.timeout)
File “/usr/lib/python2.7/smtplib.py”, line 291, in _get_socket
return socket.create_connection((host, port), timeout)
File “/usr/lib/python2.7/socket.py”, line 575, in create_connection
raise err
error: [Errno 111] Connection refused
19.11.21 19:22:13.407 MODULE ( ERROR ) : send_token(): Error sending token with via ‘email’ to ‘tmarvin’.
19.11.21 19:22:13.416 MODULE ( PROCESS ) : Error sending token: [Errno 111] Connection refused
