Packages lost after upgrade 5.0-3 errata614 to 5.0-4
hi, I upgraded from 5.0-3 errata614 to 5.0-4 and it lost a lot of univention packages, meaning they where missing after the upgrade.
the obvious one was univention-samba4 which i found because samba was not working
now I found that also univention-s4-connector was missing.
I installed both packages manually via apt. is there a check for further missing packages?
but is there a system-check to get confirmation that my system is still in a healthy status and I’m not overlooking some other internal problems induced by this faillure??
thanks in advance
You can check /var/log/dpkg.log as well as /var/log/apt to see what got removed and not updated. Might take some time, but if I remember correctly the latter should give clues why they got removed.
