I’am using here UCS 5.0-3 errata601. I have activated the automatic updates (daily). This also works very well. Only now and then, depending on which packages are installed, you have to restart the server. Now there is an option “Restart after package maintenance”.
This option allows to optionally perform an automatic restart of the system after release updates, either directly or after the specified time interval in hours.
On normal Debian/Ubuntu systems, the system automatically detects when a reboot is required. Where do I set this in UCS? Do not want to restart all servers every day.
During an update some packages may create /run/univention-updater-reboot which will trigger the at job. This will usually happen with patchlevel updates but certainly not for every update.
