I would also avoid to install those application on a primary.
There are some dependencies (dont know exactly which) that the App Suite can not be installed on a managed node. Most likely related to the additional auth-packages.
But you can install on other roles like backup or replica. Applications with enhanced LDAP-usiage are always candidate for a replica directory node.
