OX enable ActiveSync
ich wollte mit dem Befehl
/opt/open-xchange/sbin/changecontext -c 1 -A oxadminmaster -P admin_master_password --access-usm on --access-active-sync on
für den gesamten Content ActiveSync aktivieren. Jetzt kommt aber folgende Fehlermeldung:
HAbe es mit -c 10 für Content 10 auch versucht. Selber Fehler.
/opt/open-xchange/sbin/changecontext -c 1 -A oxadminmaster -P password --access-usm on --access-active-sync on
context 1 could not be changed:
Server response:
Authentication failed
at com.openexchange.admin.rmi.impl.BasicAuthenticator.doAuthentication(BasicAuthenticator.java:188)
at com.openexchange.admin.rmi.impl.OXContext.change(OXContext.java:333)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:357)
at sun.rmi.transport.Transport$2.run(Transport.java:203)
at sun.rmi.transport.Transport$2.run(Transport.java:200)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:199)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:568)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:829)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.access$400(TCPTransport.java:620)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler$1.run(TCPTransport.java:685)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler$1.run(TCPTransport.java:682)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:682)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:622)
at java.lang.Thread.run(Thread.java:748)
at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:283)
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:260)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:161)
at java.rmi.server.RemoteObjectInvocationHandler.invokeRemoteMethod(RemoteObjectInvocationHandler.java:227)
at java.rmi.server.RemoteObjectInvocationHandler.invoke(RemoteObjectInvocationHandler.java:179)
at com.sun.proxy.$Proxy0.change(Unknown Source)
at com.openexchange.admin.console.context.Change.maincall(Change.java:94)
at com.openexchange.admin.console.context.ChangeCore.commonfunctions(ChangeCore.java:110)
at com.openexchange.admin.console.context.Change.(Change.java:73)
at com.openexchange.admin.console.context.Change.main(Change.java:77)
Hat sich erledigt. Ich musste auf dem DC noch manuell ein paar Packete installieren dann ging es.
