OX-Documents doesn't work unter 4.4-7
With the newest version of OX-Documents (v. 7.10.4-ucs1) and UCS (4.4-7) we have one problem. If I open an existing document a new tab opens and then OX-Documents is loading forever…
grafik
Nothing else than this loading-symbol, no matter if I wait 10min or 1 hour.
Sometimes it says the document is very large, so it could take a few minutes, but same here.
grafik
Nobody has any idea or maybe a guess?
is the document-converter service running?
Yes the service “open-xchange-documentconverter-server” is running!
Any other ideas maybe? I cant find anything which could it be…also no logs…
Are the ceritificates ok?
(Letsencrypt seems not work fine at the moment - see System-diag)
Yes i think so!
Where did you spot that?
thank you
No idea? Nobody else has this problem?
Even if i open a new, empty, never touched document the same problem:
grafik
No errors or something like that in the “/var/log/open-xchange/open-xchange.log.0”.
No reinstall or other (lower) version helped… it seems to be a problem which is not connected exactly with the version…
Any idea maybe which service, rights or anything else this problem could come from?
