OX AppSuite with UCS SAML SSO :: configuration advise
Hello forum,
has anyone an advise for me how to get OX AppSuite running with SSO?
Where do I find the information to fill in /opt/open-xchange/etc/saml.properties of my UCS-Server
# Configuration of the SAML core feature.
# Sets the entity ID of the service provider.
# This property is mandatory.
# Default: <empty>
com.openexchange.saml.entityID =
# Sets the human-readable name of the service provider.
# Default: <empty>
com.openexchange.saml.providerName =
# Sets the URL of the local assertion consumer service (ACS). This value is used within
# authentication requests, compared against Destination attributes in IdP responses
# and will be contained in the service providers metadata XML. The according endpoint
# is always registered with '{prefix}/saml/acs' as servlet alias.
# Default: <empty>
# Example: https://appsuite.example.com/appsuite/api/saml/acs
com.openexchange.saml.acsURL =
# Sets the URL of the local single logout service. This value is compared against Destination
# attributes in IdP responses and will be contained in the service providers metadata XML.
# The according endpoint is always registered with '{prefix}/saml/sls' as servlet alias.
# This property is mandatory if 'com.openexchange.saml.enableSingleLogout' is 'true'.
# Default: <empty>
# Example: https://appsuite.example.com/appsuite/api/saml/sls
com.openexchange.saml.slsURL =
# The entity ID of the IdP. It will be used to validate the 'Issuer' elements of SAML responses.
# Default: <empty>
com.openexchange.saml.idpEntityID =
# The URL of the IdP endpoint where authentication requests are to be sent to.
# Default: <empty>
com.openexchange.saml.idpAuthnURL =
# The URL of the IdP endpoint where logout requests are to be sent to.
# Default: <empty>
com.openexchange.saml.idpLogoutURL =
I really could use a little help around here :wink:
Moin,
I was guided by AppSuite:UCS SAML SSO with OX App Suite - Open-Xchange in the past, is that sufficient for you?
Best regards
Jan-Luca
Mastodon
