Univention DC Master 4.2-2
Zugriff auf https://domain/owncloud meldet:
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /owncloud.
Reason: Error reading from remote server
root 20601 0.0 0.0 117484 3744 ? Sl 21:39 0:00 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 40001 -container-ip **172.17.0.1** -container-port 443
root 20610 0.0 0.0 190960 3552 ? Sl 21:39 0:00 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 40000 -container-ip **172.17.0.1** -container-port 80
Im Container selbst, läuft kein Webserver, was der Grund sein sollte:
root@owncl-61986644:/# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 10676 1656 ? Ss 21:39 0:00 init [2]
root 1419 0.0 0.0 196 36 ? S 21:39 0:00 runsvdir -P /etc/service log: .................................................................................................................
root 1427 0.0 0.0 44476 2644 ? Sl 21:39 0:00 /usr/sbin/rsyslogd -c5
root 1442 0.0 0.0 50316 3232 ? Ss 21:39 0:00 /usr/sbin/sshd
root 1455 0.0 0.0 99312 2368 ? Ssl 21:39 0:00 /usr/sbin/nscd
root 1469 0.0 0.0 10460 1668 ? Ss 21:39 0:00 /usr/sbin/inetd
daemon 1612 0.0 0.0 16684 144 ? Ss 21:39 0:00 /usr/sbin/atd
root 1634 0.0 0.0 10484 1736 ? Ss 21:39 0:00 /usr/sbin/cron
root 1856 0.0 0.0 36172 3780 ? Ss 21:39 0:00 /usr/lib/postfix/master
postfix 1858 0.0 0.0 38236 3752 ? S 21:39 0:00 pickup -l -t fifo -u
postfix 1859 0.0 0.0 38404 3940 ? S 21:39 0:00 qmgr -l -t fifo -u
root 2274 0.0 0.0 89852 5512 ? S 22:05 0:00 /USR/SBIN/CRON
root 2277 0.0 0.0 4196 544 ? Ss 22:05 0:00 /bin/sh -c [ -x /usr/share/univention-updater/univention-updater-check ] && /usr/sbin/jitter 600 /usr/share/univention-updater/univention-upd
root 2278 0.0 0.0 9236 2136 ? S 22:05 0:00 /bin/bash /usr/sbin/jitter 600 /usr/share/univention-updater/univention-updater-check
root 2279 0.0 0.0 4116 428 ? S 22:05 0:00 sleep 550
root 2285 4.0 0.0 10116 3284 ? Ss 22:05 0:00 /bin/bash
root 2293 0.0 0.0 6904 1624 ? R+ 22:05 0:00 ps aux
root@owncl-61986644:/# ifconfig eth0 | grep inet
inet addr:**172.17.0.1** Bcast:0.0.0.0 Mask:255.255.0.0
Jemand eine Idee? Owncloud wurde über die GUI installiert - scheinbar ging hier aber was in die Hose?
owncloud82
Latest version: 9.1.4-20170427
Installations: ucs.domain.intranet
