Hallo Leute,
ich wollte bei einem anderen Kunden ein Upgrade von Owncloud 8.2 auf 9.0 durchführen. Leider bekomme ich immer Fehler.
root@UC01RZ03:~# univention-app info
UCS: 4.1-4 errata439
App Center compatibility: 4
Installed: adconnector=10.0 samba-memberserver=4.3
Upgradable:
root@UC01RZ03:~# cat /etc/ldap/slapd.conf | grep owncloud
include /var/lib/univention-ldap/local-schema/owncloud.schema
root@UC01RZ03:~# ucr search --brief repository/online/component/owncloud82_
repository/online/component/.*: <empty>
root@UC01RZ03:~# ucr search --brief repository/* | grep cloud |wc -
0 0 0 -
Ich habe nach dieser Anleitung gearbeitet:
http://wiki.univention.de/index.php?title=OwnCloud_App_Migration
LOG:
root@UC01RZ03:/usr/share/univention-appcenter/apps/owncloud82# univention-app install owncloud82=9.1.4-20170427
Going to install ownCloud 9.1 (9.1.4-20170427)
Password for Administrator:
Stopping Univention iptables configuration::.
Starting Univention iptables configuration::.
ownCloud 9.1.4
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as
published by the Free Software Foundation, either version 3 of the
License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Do you agree [y/N]? y
Creating data directories for owncloud82...
Copying /var/cache/univention-appcenter/owncloud82_20170427133539.schema
Registering UCR for owncloud82
Marking owncloud82=9.1.4-20170427 as installed
File: /etc/univention/service.info/services/univention-appcenter.cfg
Setting ports for apache proxy
Multifile: /etc/apache2/sites-available/default-ssl
Creating /etc/init.d/docker-app-owncloud82
Adding system startup for /etc/init.d/docker-app-owncloud82 ...
/etc/rc0.d/K14docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
/etc/rc1.d/K14docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
/etc/rc6.d/K14docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
/etc/rc2.d/S41docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
/etc/rc3.d/S41docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
/etc/rc4.d/S41docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
/etc/rc5.d/S41docker-app-owncloud82 -> ../init.d/docker-app-owncloud82
Adding localhost to LDAP object
Setting overview variables
File: /var/www/ucs-overview/entries.json
Reloading web server config: apache2.
Es wurden 0 B in 0 s geholt (0 B/s)
Starting MySQL database server: mysqld already running.
owncloud82=9.1.4-20170427 already has its database
Registering schema /usr/share/univention-appcenter/apps/owncloud82/owncloud82.schema
INFO: No change of core data of object owncloud82.
No modification: cn=owncloud82,cn=ldapschema,cn=univention,dc=ppa,dc=local
WARNING: cannot append owncloud82 to appidentifier, value exists
Waiting for activation of the extension object owncloud82:.....................................................ERROR
ERROR: Master did not mark the extension object active within 180 seconds.
Registering schema file /usr/share/univention-appcenter/apps/owncloud82/owncloud82.schema failed
Aborting...
Going to remove ownCloud 9.1 (9.1.4-20170427)
No hostdn for owncloud82 found. Nothing to remove
Removing any system startup links for /etc/init.d/docker-app-owncloud82 ...
Removing localhost from LDAP object
Installing join script /var/cache/univention-appcenter/owncloud82_20170427133539.uinst
copyright (c) 2001-2017 Univention GmbH, Germany
Running 01univention-ldap-server-init.inst skipped (already executed)
Running 02univention-directory-notifier.inst skipped (already executed)
Running 03univention-directory-listener.inst skipped (already executed)
Running 04univention-ldap-client.inst skipped (already executed)
Running 05univention-bind.inst skipped (already executed)
Running 08univention-apache.inst skipped (already executed)
Running 10univention-ldap-server.inst skipped (already executed)
Running 11univention-heimdal-init.inst skipped (already executed)
Running 11univention-pam.inst skipped (already executed)
Running 15univention-directory-notifier-post.inst skipped (already executed)
Running 15univention-heimdal-kdc.inst skipped (already executed)
Running 18python-univention-directory-manager.inst skipped (already executed)
Running 20univention-directory-policy.inst skipped (already executed)
Running 20univention-join.inst skipped (already executed)
Running 26univention-nagios-common.inst skipped (already executed)
Running 26univention-samba.inst skipped (already executed)
Running 30univention-appcenter.inst skipped (already executed)
Running 30univention-nagios-client.inst skipped (already executed)
Running 31univention-nagios-ad-connector.inst skipped (already executed)
Running 34univention-management-console-server.inst skipped (already executed)
Running 35univention-appcenter-docker.inst skipped (already executed)
Running 35univention-management-console-module-adconnector.inst skipped (already executed)
Running 35univention-management-console-module-appcenter.inst skipped (already executed)
Running 35univention-management-console-module-diagnostic.inst skipped (already executed)
Running 35univention-management-console-module-ipchange.inst skipped (already executed)
Running 35univention-management-console-module-join.inst skipped (already executed)
Running 35univention-management-console-module-lib.inst skipped (already executed)
Running 35univention-management-console-module-mrtg.inst skipped (already executed)
Running 35univention-management-console-module-passwordchange.inst skipped (already executed)
Running 35univention-management-console-module-quota.inst skipped (already executed)
Running 35univention-management-console-module-reboot.inst skipped (already executed)
Running 35univention-management-console-module-services.inst skipped (already executed)
Running 35univention-management-console-module-setup.inst skipped (already executed)
Running 35univention-management-console-module-sysinfo.inst skipped (already executed)
Running 35univention-management-console-module-top.inst skipped (already executed)
Running 35univention-management-console-module-ucr.inst skipped (already executed)
Running 35univention-management-console-module-udm.inst skipped (already executed)
Running 35univention-management-console-module-updater.inst skipped (already executed)
Running 36univention-management-console-module-apps.inst skipped (already executed)
Running 40univention-virtual-machine-manager-schema.inst skipped (already executed)
Running 81univention-ad-connector.inst skipped (already executed)
Running 81univention-nfs-server.inst skipped (already executed)
Running 90univention-bind-post.inst skipped (already executed)
Running 91univention-saml.inst skipped (already executed)
Running 92univention-management-console-web-server.inst skipped (already executed)
Running 98univention-pkgdb-tools.inst skipped (already executed)
Running 51owncloud82-uninstall.uinst done
Bitte beachten Sie, dass durch die Deinstallation dieser App nicht alle
Daten automatisch gelöscht werden. Vor einer wiederholten Installation der
ownCloud-App sollte das Paket "owncloud" mit "--purge" endgültig entfernt
und das Datenverzeichnis /var/lib/owncloud rekursiv gelöscht oder
verschoben werden.
Press [ENTER] to continue
Was kann ich noch tun?
