Yesterday I want to upgrade to the newest Version of ownCloud on my UCS 4.4 Server.
For the update all is running fine.
During the Update a message came up: “Setup is unsuccessfull - please check the app.log”
21750 actions.configure 20-05-18 22:20:00 [ INFO]: Configuring 4.3/owncloud=10.3.2-1
21750 settings 20-05-18 22:20:00 [ INFO]: Unsetting OWNCLOUD_MARKETPLACE_APIKEY
21750 settings 20-05-18 22:20:00 [ INFO]: Setting OWNCLOUD_DOMAIN to 'localhost'
21750 settings 20-05-18 22:20:00 [ INFO]: Setting OWNCLOUD_SUB_URL to '/owncloud'
21750 settings 20-05-18 22:20:00 [ INFO]: Setting OWNCLOUD_UPDATE_CHECKER to 'false'
21750 settings 20-05-18 22:20:00 [ INFO]: Setting OWNCLOUD_DEFAULT_LANGUAGE to 'en'
21750 settings 20-05-18 22:20:00 [ INFO]: Setting OWNCLOUD_LOST_PASSWORD_LINK to 'true'
21750 settings 20-05-18 22:20:00 [ INFO]: Unsetting OWNCLOUD_LICENSE_KEY
21750 settings 20-05-18 22:20:00 [ INFO]: Setting OWNCLOUD_LOG_LEVEL to '3'
21750 docker.configure.container.4c0c 20-05-18 22:20:00 [ DEBUG]: Using container.4c0c for container 4c0c30c513050380da85a14149073f611cf03e6eb111133228c7b864dc2fb62f
21750 docker.configure.container.4c0c 20-05-18 22:20:00 [ DEBUG]: Calling docker exec -u root 4c0c30c513050380da85a14149073f611cf03e6eb111133228c7b864dc2fb62f which ucr
21750 actions.configure 20-05-18 22:20:02 [ WARNING]: ucr cannot be found, falling back to changing the database file directly
21750 actions.configure.progress 20-05-18 22:20:02 [ DEBUG]: 100
21750 actions.upgrade.progress 20-05-18 22:20:02 [ DEBUG]: 50
21750 actions.upgrade 20-05-18 22:20:02 [ INFO]: Executing interface restore_data_before_setup for owncloud
21750 actions.upgrade 20-05-18 22:20:02 [ INFO]: No interface defined
21750 actions.upgrade 20-05-18 22:20:02 [ INFO]: Executing interface setup for owncloud
21750 actions.upgrade 20-05-18 22:20:03 [ INFO]: Copying App Center's setup to container's /usr/share/univention-docker-container-mode/setup_custom
21750 actions.upgrade.container.4c0c 20-05-18 22:20:03 [ DEBUG]: Using container.4c0c for container 4c0c30c513050380da85a14149073f611cf03e6eb111133228c7b864dc2fb62f
21750 actions.upgrade.container.4c0c 20-05-18 22:20:03 [ DEBUG]: Calling docker exec -u root 4c0c30c513050380da85a14149073f611cf03e6eb111133228c7b864dc2fb62f /usr/share/univention-docker-container-mode/set$
21750 actions.upgrade.container.4c0c 20-05-18 22:20:28 [ INFO]: [02.DOCKER_SETUP] Enable user_ldap app
21750 actions.upgrade.container.4c0c 20-05-18 22:20:38 [ INFO]: .
21750 actions.upgrade.container.4c0c 20-05-18 22:20:38 [ INFO]: [02.DOCKER_SETUP] user_ldap enabled successfully! after 1 tries
21750 actions.upgrade.container.4c0c 20-05-18 22:20:38 [ INFO]: [02.DOCKER_SETUP] Waiting for LDAP app testing...
21750 actions.upgrade.container.4c0c 20-05-18 22:20:43 [ INFO]: ...
21750 packages 20-05-18 22:20:43 [ DEBUG]: Releasing LOCK
21750 actions.upgrade 20-05-18 22:20:43 [CRITICAL]: Setup script failed!
21750 actions.upgrade 20-05-18 22:20:43 [ WARNING]: Aborting...
21750 utils 20-05-18 22:20:43 [ DEBUG]: send_information: action=upgrade app=owncloud value={'code': 137, 'stderr': ['[02.DOCKER_SETUP] Enable user_ldap app', '.', '[02.DOCKER_SETU$
21750 utils 20-05-18 22:20:43 [ DEBUG]: tracking information: {'status': 416, 'uuid': '7578ab49-c8c6-4a13-84b8-6a94161b3d86', 'app': u'owncloud', 'value': {'code': 137, 'stderr': [$
21750 actions.upgrade-search 20-05-18 22:20:44 [ DEBUG]: Calling upgrade-search
21750 actions.upgrade-search.progress 20-05-18 22:20:44 [ DEBUG]: 0
21750 actions.upgrade-search 20-05-18 22:20:44 [ DEBUG]: Checking 4.3/owncloud=10.3.2-1
21750 actions.upgrade-search 20-05-18 22:20:44 [ INFO]: Executing interface update_available for owncloud
21750 actions.upgrade-search 20-05-18 22:20:44 [ INFO]: No interface defined
21750 actions.upgrade-search.progress 20-05-18 22:20:44 [ DEBUG]: 100
21750 actions.upgrade.progress 20-05-18 22:20:44 [ DEBUG]: 100
After that the ownCloud-Instance is brocken.
What is the problem - How can I solve it?
