Operation not permitted
While updating univention-web-js (4.0.1-42A~5.0.0.202110051223), i got the error “operation not permitted” at /usr/share/univention-web/js/dojo/dojo.js.uncompressed.js.dpkg-new.
Have someone ever seen this issue ?
Hi. I found the error.
An installed Sophos AntiVirus Instance causes the issue. After disabling Sophos, I installed the update without a problem.
sudo /opt/sophos-av/bin/savdctl disable / enable
