Openproject 3 errors
Not able to install openproject from appcente, getting following error:
3 errors occurred:
  • Something went wrong while joining the systemFurther information can be found in the following log file on each of the involved systems:
    /var/log/univention/appcenter.log
  • Setup failed
  • Setup script failed!
Hello @vijendra,
can you please look in your appcenter.log file for the following entry and paste some lines around it for context?
 [    INFO]: Launching installer for openproject...
 [ WARNING]: Selected addons: legacy-installer mysql apache2 repositories smtp memcached openproject
There should be a reason mentioned, why the setup script failed.
Login to your UCS system via SSH and go to /var/log/univention/appcenter.log.
Best regards,
Nico
Hello @vijendra
an issue with the app setup has been detected and fixed last week. Does the installation of OpenProject work for you now?
Best regards,
Nico
