Opening Virtual Machine management console
I am having difficulties opening the Virtual Machine management console. I do have the KVM virtualization Server installed. please help any and all will be appreciated.
Hi yesman1232,
do you also have installed the UVMM itself?!
have a look at the ‘App Center’ -> (filter for virtualization) and install ‘UCS Virtual Machine Manager’. after installation you find it on the specific server following ‘System - > Virtual Machines (UVMM)’ >> http:///univention-management-console/?#module=uvmm:uvmm:0:
best regards
Nico
Nicost,
I have found the Virtual Machines (UVMM). My apologies for my late reply. Thank you for your help.
