Hi, as per my other thread I am trying to install and use XWiki. XWiki needs the OpenID Connect Provider. I ran into the problem that the xwiki installation always failed an UCS 5.x, I tried 4.4x and here the app center is a bit clearer on the issue: “cannot find OpenID Connect Provider”. I tried to install this via univention-app install, but this only throws a
root@xwiki:~# univention-app install openid-connect-provider
Going to install OpenID Connect Provider (2.2-konnect-0.33.11-2)
(must_not_be_end_of_life) This application was discontinued and may not be installed
anymore
Password for Administrator:
Unable to install openid-connect-provider. Aborting...
Is there a possibility to install the dependencies for XWiki? Can I “hack” this and install XWiki without the OpenID Connect Provider? Thank you in advance!
I tried XWiki some time back and also had trouble with the OID-Connector. I ended up uninstalling the OID plugin inside XWIKI and installed one for LDAP. Connected XWiki to Univention using LDAP, worked fine.
unfortunately, the install dependencies could not be resolved, because the dependency is discontinued. So I wasn’t even able to install XWiki (to make changes in the config afterwards).
BUT alas: I managed to install the openid connect provider anyway.
I do not think that should be the solution, but I was able to install the dependency and afterwards XWiki (install is currently running). I thought the app-team has an eye on situations like this.
Vielen Dank für die umfassende Information, schaue ich mir an. Die Dependencies berührt das aber nicht → wenn (z.B.) XWiki vom OpenID Paket abhängig ist, hilft es mir nicht KeyCloak eingerichtet zu haben, korrekt?
