ich wollte mein Android Kalender über CalDAV mit dem Kalender von Open Xchange synchronisieren.
Die App DavDroid ist mein Favorit.
Leider findet DavDroid keinen CalDAV Dienst:
[code]2016-06-01 10:42:00 5 [ui.setup.DavResourceFinder] Finding initial carddav service configuration
2016-06-01 10:42:00 5 [ui.setup.DavResourceFinder] Checking user-given URL: https://144.76.XXX.XXX/caldav/41
2016-06-01 10:42:00 5 [HttpClient$1] → PROPFIND https://144.76.XXX.XXX/caldav/41 http/1.1
2016-06-01 10:42:00 5 [HttpClient$1] Content-Type: application/xml; charset=utf-8
2016-06-01 10:42:00 5 [HttpClient$1] Content-Length: 290
2016-06-01 10:42:00 5 [HttpClient$1] Depth: 0
2016-06-01 10:42:00 5 [HttpClient$1] <?xml version='1.0' encoding='UTF-8' ?><CARD:addressbook-description /><CARD:addressbook-home-set />
2016-06-01 10:42:00 5 [HttpClient$1] → END PROPFIND (290-byte body)
2016-06-01 10:42:00 5 [HttpClient$1] ← 405 Method Not Allowed https://144.76.XXX.XXX/caldav/41 (252ms)
2016-06-01 10:42:00 5 [HttpClient$1] Date: Wed, 01 Jun 2016 08:42:03 GMT
2016-06-01 10:42:00 5 [HttpClient$1] Server: Apache/2.2.22 (Univention)
2016-06-01 10:42:00 5 [HttpClient$1] Allow: GET,HEAD,POST,OPTIONS
2016-06-01 10:42:00 5 [HttpClient$1] Vary: Accept-Encoding
2016-06-01 10:42:00 5 [HttpClient$1] Keep-Alive: timeout=5, max=100
2016-06-01 10:42:00 5 [HttpClient$1] Connection: Keep-Alive
2016-06-01 10:42:00 5 [HttpClient$1] Content-Type: text/html; charset=iso-8859-1
Method Not Allowed
The requested method PROPFIND is not allowed for the URL /caldav/41.
Apache/2.2.22 (Univention) Server at 144.76.230.31 Port 443 [/code]
(Ich hab den Fehlerlog mal gekürzt, auf jeden Fall findet DavDroid keinen CalDAV Dienst unter den Standard URLs)
Auch mit einem neuen Testaccount und über curl wurde nichts gefunden:
[code]$ curl -kvX OPTIONS --user ‘USER:PASSWORT’ https://144.76.XXX.XXX/caldav/63
- Trying 144.76.XXX.XXX…
- Connected to XXX.de (144.76.XXX.XXX) port 443 (#0)
- Initializing NSS with certpath: sql:/etc/pki/nssdb
- skipping SSL peer certificate verification
- ALPN/NPN, server did not agree to a protocol
- SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
- Server certificate:
- subject: E=ssl@XXX.de,CN=XXX.de,OU=Univention Corporate Server,O=XXX XXX,L=DE,ST=DE,C=DE
- start date: Feb 11 09:45:34 2016 GMT
- expire date: Feb 09 09:45:34 2021 GMT
- common name: XXX.de
- issuer: E=ssl@XXX.de,CN=“Univention Corporate Server Root CA (ID=XXX)”,OU=Univention Corporate Server,O=XXX,L=DE,ST=DE,C=DE
- Server auth using Basic with user ‘davdroid-test’
OPTIONS /caldav/63 HTTP/1.1
Host: XXX.de
Authorization: Basic XXXXXX
User-Agent: curl/7.43.0
Accept: /
< HTTP/1.1 200 OK
< Date: Sat, 04 Jun 2016 09:30:44 GMT
< Server: Apache/2.2.22 (Univention)
< Allow: GET,HEAD,POST,OPTIONS
< Content-Length: 0
- Connection #0 to host XXX.de left intact[/code]
Aber der Sync mit Mozilla Lightning hat funktioniert, also hab ich mal den Mozilla Header miteingefügt und siehe da:
[code]$ curl -kvX OPTIONS -H “User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Thunderbird/45.1.0 Lightning/4.7.1” --user ‘USER:PASSWORT’ https://XXX.de/caldav/
- subject: E=ssl@XXX.de,CN=XXX.de,OU=Univention Corporate Server,O=XXX,L=DE,ST=DE,C=DE
- Server auth using Basic with user ‘USER’
OPTIONS /caldav/ HTTP/1.1
Host: XXX.de
Accept: /
< HTTP/1.1 200 OK
< Date: 2016-06-04T12:54:34Z
< Server: Openexchange WebDAV
< Allow: GET,PUT,DELETE,HEAD,OPTIONS,TRACE,PROPPATCH,PROPFIND,MOVE,COPY,LOCK,UNLOCK,REPORT,ACL,MKCALENDAR
< DAV: 1, 2, 3, access-control, calendar-access, addressbook, extended-mkcol, calendar-auto-schedule, calendar-schedule, calendarserver-sharing, calendarserver-principal-search, calendarserver-principal-property-search, calendarserver-private-comments, extended-mkcol, calendar-managed-attachments
< Accept-Ranges: bytes
< MS-Author-Via: DAV
< Content-Length: 0
< Via: 1.1 XXX.de[/code]
Demnach hängt es vom Header ab ob Open Xchange einen CalDAV Dienst bietet oder nicht.
Ist diese Angewohnheit so gewollt und wenn ja mit welcher Begründung? Denn damit sperrt der Open Xchange Kalender DavDroid aus was für mich jetzt heißt eine andere CalDAV App zu finden
