Open Project 9.0.2
Hello
i’m tryng to install open project 9.0.2 with the appcenter and i have 3 failed…
My univention is in a new vm without other soft intallation.
Could you help me please?
Thanks
Hello @info2p,
welcome to Univention Help. To be able to help you, I need some more information. First, please provide relevant details. Regarding the VM, did you use the virtual app appliance, or installed the app via the App Center UMC module in the UCS management system or via command-line with univention app install on a fresh plain UCS virtual machine?
Second, I need some information from your /var/log/univention/appcenter.log regarding the installation. Please look for the line saying “Going to install openproject” and look for warnings, tracebacks or error messages in the following lines. Please post them here.
And also have a look at /var/log/univention/join.log and search for “openproject” and have a look at the following lines. Are there any warnings or errors?
Best regards,
Nico
