Open Port-Range in UCS Firewall
I need to open a range of ports on my UCS 4.4 Server for internal use (Veeam B&R need this ports for the instant file restore)
The Ports are TCP: 2500-5000 and TCP 49152-65535
How can I set this setting? I only found examples with one port. And I am confused: Is the rigth syntax “security/packetfilter/package/veeam/tcp/2500/…” or “security/packetfilter/veeam/tcp/2500/…” for me?
The following syntax will do:
ucr set security/packetfilter/tcp/2500:5000/all=ACCEPT
The other range is already open by default if you’re running Samba 4 (see /etc/security/packetfilter.d/10_univention-firewall_start.sh).
