a customer from us just bought the integration edition of OnlyOffice.
At the moment he has the AppCenter-Docker-Container in use.
I got a license key from OnlyOffice.
Can I just put it in the Docker container and restart it?
I would have to do that every time the docker container gets updated, which wouldn’t be too bad, but I guess it’s not that easy.
If I need to download a complete new container, which steps are necessary to make it run like before?
I guess I need to uninstall the UCS-App before, right?
If I uninstall the UCS-App I will lose some of the configuration done by Univention, which works now. I don’t want that.
One the other hand, if I just stop the old container and start the new one which the correct mount points, I will get some problems, when the system is being upgraded or even restarted.
you can see the details of the container from Univention including all volumes. That should give you the directories you need to mount into the other image.
Still I would do a backup of these directories before starting the other container.
the following text is part of the app description:
After installation ONLYOFFICE Community edition is installed with this app, limited to 20 sessions. If you want to increase the number of sessions, please obtain ONLYOFFICE Integration Edition via ‘Buy now’ .
Therefore I would expect that you can also run the commercial edition of onlyoffice on univention (without the need to remove the app and run the container directly). Maybe @ngulden can clarify.
It would be nice to have an UCS-approved solution for that.
I pressed the “Buy” button, but it only asked me “How many connections” and there is no “I have a license already”
Wouldn’t it be enough to tell UCS to use onlyoffice-ie instead of onlyoffice-ds?
The name of the container is not an UCR variable though.
after I saw your posting yesterday, I got directly in contact with ONLYOFFICE. My expectation is to take the license file, place it on the server and then the app works as ONLYOFFICE Integration Edition.
With that goal in mind I discuss it with ONLYOFFICE and hope for an update of the app. Unfortunately, this probably will not be an immediate solution.
Since you have the Integration Edition, I suggest to get in contact with the ONLYOFFICE support.
Nico, Thanks, we will try to find a work around as soon as possible. @roland.gsell
[quote=]
[/quote]
At the moment I would recommend to put the file into /var/lib/univention-appcenter/apps/onlyoffice-ds/Data
There is no need to restart the container.
The DocumentServer will work in the activated mode (with connection limitats according to your license)
We are currently discussing how we could easily switch to documentserver-ie (a difference in the interfaces remains even after activating the product with your license file)
Hello, I also bought the ONLYOFFICE Integration Edition. I would like to unlock them in USC.
Is there a way to install and integrate the onlyoffice / documentserver-ie docker. The previous variant (onlyoffice-ds + key) does not activate the mobile editor.
