the last days I tested odoo ITIS easy Business V14, but without a configured mailserver on my UCS 4.4-9 errata 1227.
Hint for users, who tried the older odoo-version(s):
The odoo ITIS easybusiness V14 is the latest recent main version, as I got told from ITIS via a phone call last week. ITIS releases every year a new version.
On my UCS server I did create several users and marked “Activate user for odoo ITISeasybusiness (UE)”
After login in odoo using the database ITISeasybusiness_LIVE I went to settings - users but none of the new users was visible.
So I checked the settings but I cannot find any error:
LDAP seems to be OK:
There are three LDAP entries - all are nearyly the same
except the number in the red box:
The var/log/odoo-server.log in the odoo Docker container shows no error.
Same with the log files in /var/log/univention.
The user can login into odoo without any problems then. But only after his first login he becomes visible in odoo.
Is there a way, to make the users visible in odoo, before the first login of the users?
