O365 login not working after UCS 4.4 upgrade
Hi all,
after i upgraded our system to 4.4, SSO to O365 is not working anymore, see the attached screenshot:
ucssso
Because of the increased complexity of the apache2 configuration with php handlers, I cant find the error.
I think it must be somewhere in the SSO configuration, here’s my config file (I can’t remember to change something):
#          univention-config-registry.
#          Please edit the following file(s) instead:
#          univention-config-registry ueberschrieben werden.
#          Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
#       /etc/univention/templates/files/etc/apache2/sites-available/univention-saml.conf
Alias /simplesamlphp/saml2/idp/certificate /etc/simplesamlphp/ucs-sso.XXXXX.de-idp-certificate.crt
<Directory "/etc/simplesamlphp">
        <Files "ucs-sso.XXXXX.de-idp-certificate.crt">
                Require all granted
        </Files>
</Directory>
Alias /simplesamlphp /usr/share/simplesamlphp/www
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^/?simplesamlphp/(.*) https://%{SERVER_NAME}/simplesamlphp/$1 [R,L]
<Directory /usr/share/simplesamlphp/www/>
        <FilesMatch ".+\.ph(p[345]?|t|tml)$">
                SetHandler php-cgi
        </FilesMatch>
        Action php-cgi /saml-bin/php-cgi
        Order allow,deny
        Allow from all
</Directory>
<Directory /var/www/saml/>
        Options -Indexes
</Directory>
<IfModule mod_ssl.c>
<VirtualHost *:443>
        IncludeOptional /etc/apache2/sso-vhost.conf.d/*.conf
        SSLEngine on
        SSLProxyEngine on
        ServerName ucs-sso.XXXXX.de
        SSLCACertificateFile /etc/univention/letsencrypt/intermediate.pem
                SSLCertificateChainFile /etc/univention/letsencrypt/intermediate.pem
        DocumentRoot /var/www/
        RedirectMatch ^/$ /simplesamlphp/
        ScriptAlias /saml-bin /var/www/saml
        SuexecUserGroup samlcgi samlcgi
        RewriteEngine on
        RewriteCond %{HTTP:Authorization}  !^$
        RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
        Include /etc/apache2/sites-available/univention-proxy.conf
</VirtualHost>
<VirtualHost *:80>
        RewriteEngine on
</VirtualHost>
</IfModule>
This error is pretty painful as nobody is able to Login to Office 365 at the moment!
Any ideas?
If more information is required, just let me know.
Thanks!
Felix
Please post the output of the following commands:
univention-check-templates
dpkg -l '*saml*'
Hi Moritz, thanks for your answer!
First command:
root@intern:~# univention-check-templates
WARNING: The following UCR files are modified locally.
Updated versions will be named FILENAME.dpkg-*.
The files should be checked for differences.
/etc/univention/templates/files/etc/apache2/sites-available/000-default.d/00start
/etc/univention/templates/files/etc/apache2/sites-available/000-default.d/99end
/etc/univention/templates/files/etc/apache2/sites-available/ssl.d/00start
/etc/univention/templates/files/etc/apache2/sites-available/ssl.d/99end
Those edits are made on purpose and do not affect the ucs-sso sub-domain. Those were made years ago to have a second vhost on the server to serve second webpage.
Second command:
root@intern:~# dpkg -l '*saml*'
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
| Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
         Halb installiert/Trigger erWartet/Trigger anhängig
|/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
||/ Name                                                      Version                           Architektur                       Beschreibung
ii  cy2-saml                                                  1.8.0-3A~4.2.0.201708041146       amd64                             SASL plugin for SAML authentication
ii  pam-saml                                                  1.8.0-3A~4.2.0.201708041146       amd64                             PAM module for SAML authentication
ii  python-pysaml2                                            3.0.0-5A~4.2.0.201702151906       all                               SAML Version 2 to be used in a WSGI environment - Python 2.x
ii  simplesamlphp                                             1.14.11-1+deb9u1A~4.3.0.201803051 all                               Authentication and federation application supporting several protocols
ii  univention-saml                                           6.0.2-1A~4.4.0.201903061529       all                               Integrates simpleSAMLphp Identity Provider into UCS
ii  univention-saml-schema                                    6.0.2-1A~4.4.0.201903061529       all                               UCS simpleSAMLphp ldap integration
Regards,
Felix
Big update:
Solved the problem for now! Issue was:
I used Letsencrypt to obtain the certificate for the ucs-sso domain, too.
I think since the last update, the Letsencrypt app created apache2 VHost configs for all the subdomains set in the app’s settings. Those overwrote the ucs-sso SAML config and prevented external access to the saml backend.
After commenting out the whole ucs-sso VHost in /etc/apache2/sites-available/univention-letsencrypt.conf, it’s working again.
I think this is maybe a bigger issue other people might experience, too…
Hi! Commenting out those lines did lead to the self-signed UCS certificate to be used for the ics-sso vHost. So i had to change the linex in the generated lines in /etc/apache2/sites-available/univention-saml.conf as well:
#       SSLCertificateFile /etc/univention/ssl/ucs-sso.<yourdomain>/cert.pem
#       SSLCertificateKeyFile /etc/univention/ssl/ucs-sso.<yourdomain>/private.key
#       SSLCACertificateFile /etc/univention/ssl/ucsCA/CAcert.pem
So this indeed is a bigger issue between the letsencrypt mechanisms not integrated correctly. That of course is not an easy task.
