[code]ucr search interface
interfaces/eth0/address: 192.168.0.117
IP address of the network interface
Categories: system-network
interfaces/eth0/broadcast: 192.168.0.255
Broadcase address of the network interface
interfaces/eth0/netmask: 255.255.255.0
Netmask of the network interface
interfaces/eth0/network: 192.168.0.0
Network of the network interface
interfaces/handler: ifplugd
samba/interfaces/bindonly:
Limits Samba to listen only on the interfaces listed in samba/interfaces.
Categories: service-samba
root@horn4null:~# ucr search samba
samba/adminusers: administrator
List of users with administrative rights in samba
samba/autostart: yes
Enable/Disable Samba start on bootup
samba/charset/display:
Charset used to print messages to stdout and stderr (should be the same as the samba/charset/unix)
samba/charset/dos:
Charset used to communicate with DOS SMB clients
samba/charset/unix:
Charset of the machine samba runs on
samba/client_use_spnego: yes
Controls whether Samba clients will try to use Simple and Protected NEGOciation
samba/deadtime: 15
Time span of inactivity in minutes before a connection is considered dead and eventually disconnected
samba/debug/level: 0
Debug level for samba processes
samba/domain/logons: auto
Enables/Disables support for windows 9X network logons and NT4 style domain services (valid values: no/auto/yes)
samba/domainmaster:
Try to acts as domain master browser
samba/enable-msdfs:
Act as a DFS server and allow DFS-aware clients to browse DFS trees
samba/enable-privileges:
Honor privileges assigned to specific SIDs
samba/encrypt_passwords: yes
Negotiate encrypted passwords with the client
samba/generate_smbpasswd: false
Enable/Disable usage of the local TDBSAM database on Samba installation
samba/getwd_cache: yes
Enables a caching algorithm to reduce the time taken for getwd() calls
samba/guest_account: nobody
Username for unauthenticated services (guest ok)
samba/homedirletter: I
Drive for the home directory
samba/homedirpath: %U
Path to the home directory for Win95/98 or NT workstations
samba/homedirserver: horn4null
Fully qualified domain name of the server providing the home directories
samba/idmap/domains:
Domain names of Windows domains for which SID to posix ID mappings should be resolved via idmap_ldap by an authenticated LDAP search in the UCS directory service
samba/invalid_users: daemon bin sys sync games man lp mail news uucp proxy majordom postgres www-data backup msql operator list irc gnats alias qmaild qmails qmailr qmailq qmaill qmailp telnetd identd ftp rwhod gdm fetchmail faxmaster
List of users that are not allowed to login to this samba service
samba/kernel_oplocks: yes
Turns the use of kernel based oplocks on/off
samba/large_readwrite: yes
Enable/disable the 64k streaming read and write varient SMB requests
samba/ldap/replication/sleep:
Milliseconds to wait for the LDAP replication to finish
samba/logonscript:
Path to netlogon script (relative to the [netlogon] service)
samba/map_to_guest: Bad User
What to do with user login requests that don’t match a valid UNIX user
samba/max_xmit: 65535
Maximum packet size that will be negotiated
samba/netbios/aliases:
Additional NetBIOS names under which the Samba server is known
samba/netbios/filter:
Regular expression matching the hosts to appear in the browse list
samba/netlogon/sync: sync
Adjust synchronisation of samba netlogon scripts
samba/oplocks: yes
Issue oplocks to file open requests
samba/os/level: 65
The level Samba advertises itself as for browse elections
samba/preserve_case: yes
Controls if new filenames are created with the case that the client passes, or if they are forced to be the default case
samba/profilepath: %U\windows-profiles%a
Specifies the directory where roaming profiles are stored
samba/profileserver: horn4null
Specifies the samba server where roaming profiles are stored
samba/read_raw: yes
Support 64 kByte packets when transferring data to clients
samba/script/addgroup: true
samba/script/addmachine: true
samba/script/adduser: true
samba/script/addusertogroup: true
samba/script/deletegroup: true
samba/script/deleteuser: true
samba/script/deleteuserfromgroup: true
samba/script/postusermodify: false
samba/script/setprimarygroup: true
samba/serverstring:
String that will show up in printer comment box and ‘net view’
samba/share/groups: no
Enable/Disable the group share
samba/share/home: yes
Enable/Disable the home directory share
samba/short_preserve_case: yes
Controls if new files which conform to 8.3 (DOS) syntax are created upper case, or if they are forced to be the default case
samba/socket_options:
Extra socket options to be used when talking with the client
samba/store_dos_attributes: yes
Attempt to read DOS attributes from a filesystem extended attribute, before mapping DOS attributes to UNIX permission bits
samba/time_server: yes
Advertises samba as a time server to Windows clients
samba/use_spnego: yes
Try to use Simple and Protected NEGOciation with Windows 2000 and XP clients
samba/user: cn=admin,dc=martina,dc=at
Alternative LDAP admin DN
samba/winbind/nested/groups: no
Enables/Disables support for nested groups
samba/winbind/trusted/domains/only: yes
Allow Samba member-servers of a samba domain to use UNIX accounts distributet via LDAP/NIS/rsync as the uid’s for winbindd users
samba/write_raw: yes
Enable the Server to write raw SMBs when transfering data from clients
[/code]
LG
Franz
(geht bei euch dir Signatur? bei mir nicht
