Hi guys,
we get the following error with 2 users, one of them the administrator. The currently installed version ist 5.0-3 errata601.
When we run diagnose we see:
"Warning: not synchronized S4 Connector Objects"
this is the output of connector-s4.log
06.03.2023 09:23:12.069 LDAP (PROCESS): sync AD > UCS: Resync rejected dn: ‘CN=Administrator,CN=Users,DC=intern,DC=domain,DC=de’
06.03.2023 09:23:12.069 LDAP (ERROR ): unexpected Error during s4.resync_rejected
06.03.2023 09:23:12.070 LDAP (ERROR ): Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/univention/s4connector/s4/init.py”, line 1760, in resync_rejected
elements = self.__search_ad_changeUSN(change_usn, show_deleted=True)
File “/usr/lib/python3/dist-packages/univention/s4connector/s4/init.py”, line 965, in __search_ad_changeUSN
usn_filter = format_escaped(’(|(uSNChanged={0!e})(uSNCreated={0!e}))’, changeUSN)
File “/usr/lib/python3/dist-packages/univention/s4connector/s4/init.py”, line 489, in format_escaped
return LDAPEscapeFormatter().format(format_string, *args, **kwargs)
File “/usr/lib/python3.7/string.py”, line 186, in format
return self.vformat(format_string, args, kwargs)
File “/usr/lib/python3.7/string.py”, line 190, in vformat
result, _ = self._vformat(format_string, args, kwargs, used_args, 2)
File “/usr/lib/python3.7/string.py”, line 234, in _vformat
obj = self.convert_field(obj, conversion)
File “/usr/lib/python3/dist-packages/univention/s4connector/s4/init.py”, line 474, in convert_field
raise TypeError(‘Filter must be string, not bytes: %r’ % (value,))
TypeError: Filter must be string, not bytes: b’408372’
Any help is appreciated!
Best regards
KaBi
