Hi@all,
This is a test environment only. Not really important. I still describe it because it could be a bug of Jitsi as Docker container on UCS5. The environment:
Role: UCS 5.0.1 Node.
FQHN: gw01.intern.lan
IP: 192.168.83.6
The scenario / test is exclusively local. Without external access. After installing Jitsi (without customization) it is under:
https://jitsi.gw01.intern.lan
accessible. Local users can start or participate in meetings. Now I try the URL using VHOST on:
https://meet.intern.lan
to change it. As it is described here:
Since this is an internal test, I am using the self-signed UCS certificates.
nano /etc/apache2/sites-available/jitsi.conf
<VirtualHost *:443>
ServerName meet.intern.lan
SSLEngine on
SSLProxyEngine on
SSLProxyCheckPeerCN off
SSLProxyCheckPeerName off
SSLProxyCheckPeerExpire off
SSLCertificateFile /etc/univention/ssl/*.gw01.intern.lan/cert.pem
SSLCertificateKeyFile /etc/univention/ssl/*.gw01.intern.lan/private.key
ProxyPass / http://localhost:8888/ retry=0
ProxyPassReverse / http://localhost:8888/
</VirtualHost>
and:
a2ensite jitsi
systemctl restart apache2
On the Master → DNS I have edit the DNS alias from
Alias: jitsi.gw01
Canonical name: gw01.intern.lan.
to:
Alias: meet.gw01
if I now call Jitsi from the LAN:
Can I start a meeting but immediately gets the message “disconnected”. See:
The message runs in heavy rotation and does not disappear. Maybe it has something to do with the UCR variables that were set during the Jitsi installation:
root@gw01:~# ucr search --brief jitsi
apache2/vhosts/jitsi.gw01.intern.lan/443/aliases:
apache2/vhosts/jitsi.gw01.intern.lan/443/enabled: true
apache2/vhosts/jitsi.gw01.intern.lan/443/files: /var/lib/univention-appcenter/apps/jitsimeet/config/vhost.conf
apache2/vhosts/jitsi.gw01.intern.lan/443/ssl/ca: /etc/univention/ssl/ucsCA/CAcert.pem
apache2/vhosts/jitsi.gw01.intern.lan/443/ssl/certificate: /etc/univention/ssl/*.gw01.intern.lan/cert.pem
apache2/vhosts/jitsi.gw01.intern.lan/443/ssl/key: /etc/univention/ssl/*.gw01.intern.lan/private.key
appcenter/apps/jitsimeet/container: e0211261ebe253fcdc0a2b823ed3154c95f62ed3493a09e247fcbba41678ef8e
appcenter/apps/jitsimeet/hostdn: cn=jitsi-33633204,cn=memberserver,cn=computers,dc=gehr,dc=lan
appcenter/apps/jitsimeet/image: docker.software-univention.de/jitsimeet-web:stable-6726-2
appcenter/apps/jitsimeet/ports/10000: 10000
appcenter/apps/jitsimeet/ports/4443: 4443
appcenter/apps/jitsimeet/status: installed
appcenter/apps/jitsimeet/ucs: 4.4
appcenter/apps/jitsimeet/version: stable-6726-2
jitsimeet/autostart: yes
jitsimeet/docker/host/address: 192.168.83.6
jitsimeet/enable/auth: true
jitsimeet/enable/guests: true
jitsimeet/ldap/filter: (&(uid=%u)(jitsimeetActivated=TRUE))
jitsimeet/public/url: https://jitsi.gw01.intern.lan
security/packetfilter/package/jitsimeet/tcp/10000/all/en: for RTP media over UDP
security/packetfilter/package/jitsimeet/tcp/10000/all: ACCEPT
security/packetfilter/package/jitsimeet/tcp/4443/all/en: for RTP media over TCP
security/packetfilter/package/jitsimeet/tcp/4443/all: ACCEPT
security/packetfilter/package/jitsimeet/udp/10000/all/en: for RTP media over UDP
security/packetfilter/package/jitsimeet/udp/10000/all: ACCEPT
with best
sven
