NFS recycle bin
Hello. Is it possible to use recycle bin with nfs sharing? With cifs, it works fine. With NFS my attempts failed. I’m trying to implement NFS with pam_mount.
Tanks,
Michael
As far as I know, the recycle bin only works flawless with smb-shares and not with nfs.
Hi!
After activating nfs, it is working with UCC, and Ubuntu creates the trash dirs …
What occurred to me, analyzing dmesg, is that a message appeared: NFSD: Using / var / lib / nfs / v4recovery as the NFSv4 state recovery directory. However nothing happens in this folder, some adjustment is probably needed. From what I’ve been researching, it seems to be possible to create the recycle bin in NFS.
Michael Voigt
Mastodon
